enable radius dynamic-authorization
Description
Enables dynamic authorization RADIUS accounting.
Syntax Description
Default
Dynamic authorization RADIUS accounting is disabled by default.
Usage Guidelines
Before you enable RADIUS on the switch, you must configure the servers used for authentication and configure the authentication string (shared secret) used to communicate with the RADIUS authentication server.
To configure the RADIUS authentication servers and shared secret, use the following command:
configure radius dynamic-authorization index [nas-ip [ignore | require] | server [host_ipaddr | host_ipV6addr | hostname] {tls {tls_port}} client-ip [client_ipaddr | client_ipV6addr] {vr vr_name} {shared-secret {encrypted} secret}
The following command enables dynamic authorization RADIUS authentication on the switch:
This command was first available in ExtremeXOS 22.1.
Platform Availability
